Cbr1000f (95) front brake removal
Old 01-16-2016, 10:35 AM
garryramp's Avatar
Default Cbr1000f (95) front brake removal
Hi guys,
This is my first post here, so please, be gentle with me.. Lol.
I have a 95 Cbr1000f and need to remove the front left calliper to free it up, it's binding a bit. Did anyone know what size spanner is needed to undo the bottom retaining pin holding the calliper to the forks, it seems to be somewhere between 11 & 12mm ish..
In sure this has been covered earlier by someone her but I can't find it so I thought I'd ask the question..
Thanks guys
Live long and keep biking!!!
Old 01-16-2016, 01:14 PM
TimBucTwo's Avatar
Yes, a 12mm should do it. Also the pin #19 is captured buy clip #20. You need to lift the clip #20 while backing the pin #19 out or you will damage the clip.
Edit: There are several size pistons in the calipers, you need to replace them where they came out of. When you are done you need to bleed the system. Bleeding LINK.
deucea
05-17-2022 02:16 AM
groutby
04-21-2014 02:38 PM
walivabuc
05-01-2013 06:52 AM
eekenterprises
01-19-2009 09:05 PM
aeroworks
02-23-2006 01:21 PM
Quick Reply: Cbr1000f (95) front brake removal
