Another Front sprocket change question
Old 11-04-2014, 06:40 PM
rdsii64's Avatar
Default Another Front sprocket change question
Tomorrow after I go pick up one of my kids friends and bring them back to my house I'm going to start my chain and sprocket replacement. So far it doesn't look like to complicated a job. I do have another question though.
I know to take off the sprocket cover I have to remove the speedo cable first. My question is, do I also have to remove the shift lever before I can take off the sprocket cover?
Old 11-05-2014, 01:10 PM
TimBucTwo's Avatar
The shift lever does need to come off.
Old 11-05-2014, 05:48 PM
hawkwind's Avatar
Take note of the exact position of the lever, so that you can replace it in the same position.
Old 11-06-2014, 07:15 AM
hmm's Avatar
hmm
hmm is offline
I think there are little marks (a line and a dot?) to help you line the lever up with the axle.
Old 11-06-2014, 08:42 PM
Sprock's Avatar
2 dots (indents) one on the shaft one outside the splines - they should align unless you plan on dropped pegs
then they outer indent gets dropped down a spline or two.
bradseabridge
07-06-2009 11:33 AM
deek98
08-20-2007 01:02 PM
Candymanmo06F4I
04-11-2007 04:07 PM
Anubis
01-28-2006 07:39 AM
Quick Reply: Another Front sprocket change question
