Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
using a front master cylinder as rear hand brake
Old Jan 1, 2009 | 03:16 PM
redforlife's Avatar
Default using a front master cylinder as rear hand brake
can you use a front master cylinder as a rear hand brake. Does the resivoir hose work when it normally mounts on top but switched around it would be on the bottom. Does it still get sufficient fluid to the cylinder?
Old Jan 1, 2009 | 06:14 PM
mofat01's Avatar
Default RE: using a front master cylinder as rear hand brake
Any radial front master works good (newer gsxr, R1, or a brembo 16x18 are what I like). Bleed thefront master in its regular position then turn it over and put it on as a handbrake, run the res tube up so fluid has to travel down into the master.
Old Jan 1, 2009 | 07:50 PM
redforlife's Avatar
thats what i was thinkin, i had the brembo setup and has the big bulky built in resivoir like the stock f4i one
Thad
F4i - Wanted
Feb 24, 2013 03:55 PM
reddoctor
May 5, 2012 02:36 AM
Christopher Barbas
Jul 22, 2009 12:41 AM
greenman100
Feb 10, 2009 06:07 PM
Jaybird180
Oct 12, 2008 02:43 PM
