Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
Trouble keeping wheelie straight
Old May 24, 2007 | 12:27 AM
05f4i16's Avatar
Default Trouble keeping wheelie straight
I've been experimenting with wheelie's and realized that when i clutch it up i find myself bearing off to the right most of the time. I tried adjusting the chain thinking maybe it wasn't even but still happens. What else could be the cause? Tire pressure maybe too high? Maybe I'm leaning to the right when I clutch it up? Any one have any suggestions? Thanks in advance
Old May 24, 2007 | 02:28 AM
Err's Avatar
Err
Default RE: Trouble keeping wheelie straight
make sure you're weight is even.
Old May 24, 2007 | 10:17 AM
BlindLOKI's Avatar
I had the same kinda problems with my bike when I started doin wheelies. After doing them day after day after day you naturally start bringing them up straighter. I think its just an unconcious weight shift or something but you just get used to it after awhile and either correct on the way up or dont have to correct at all. Also, if your doing them on a road that has a crown, you could be getting "pulled" by the road itself... another thing you learn to deal with over time...
Old May 24, 2007 | 10:27 PM
05f4i16's Avatar
makes sense. I'm sure it'll just take some getting used to and adjustments. Thanks for the help guys
Old May 25, 2007 | 10:18 PM
1 UP's Avatar
I have the exact same problem but it usualy happens when the road im on isnt perfectly level.
Old May 26, 2007 | 01:52 AM
2kgixx's Avatar
drop the pressure to 20 psi, and when it startsshifting to the right move ur body to the left as much as possible
Old May 26, 2007 | 01:54 AM
2kgixx's Avatar
also it is much easier to steer ur wheelie once u reach the bp, if ur not there its difficult, atleast for me
101cbrman
Apr 18, 2011 11:17 PM
101cbrman
Nov 2, 2010 11:42 PM
MBUAssassin
Nov 26, 2009 11:13 AM
fishfryer527
Apr 23, 2008 10:55 PM
rangerscott
Sep 27, 2007 10:20 AM
