Streetfighter no spark
1994 CBR 600 Streetfighter no spark. Bought for project no key when i bought it. I can get the starter to turn over when I jump the starter solenoid with a piece of wire. I have no spark because I took out a plug and have nothing. How do I bypass the key ignition? How to bypass the kill switch? and how to bypass any of the other sensors to kill the spark?
i hate to answer a question with a question..
but i think i dont have a choice.
so here goes....
Huh??
sorry man, but i think you need to detail your question a bit better..
i know there are lots of people on here who will def help/answer your questions.. but what exactly are you trying to do?? are trying to just get the bike running without having to use a key??? and bypass the ignision thats currently on there now.
and what do you mean " you took out the plug!!" what plug did you take out?? the ignition plug? starter plug? spark plug??? theres alot of plugs
and this is taken from the end of your question: qoute:How do I bypass the key ignition? How to bypass the kill switch? and how to bypass any of the other sensors to kill the spark?
i have no idea what you mean by that.. please dont take any offence.. i write stuff on here all the time and have to go back and edit it, because i rushed and wrote my question backwards.. anyway.. just some better details and lets see if we can help you out!! jay..
so here goes....
Huh??
. and this is taken from the end of your question: qoute:How do I bypass the key ignition? How to bypass the kill switch? and how to bypass any of the other sensors to kill the spark?
when i wired up my motor the other day, i found the same thing - except i actually had my key and kill/run switch hooked up. even so - i still wasn't getting spark. we finally figured out that there was a very thick run wire (12 or 10 gauge wire that was red/yellow stripe) that needed to be hooked up to the battery as well. once i got that hooked up - i got spark. you'll have to look at your diagram for your bike - but hopefully that helps.
