Streetfighter no spark
1994 CBR 600 Streetfighter no spark. Bought for project no key when i bought it. I can get the starter to turn over when I jump the starter solenoid with a piece of wire. I have no spark because I took out a plug and have nothing. How do I bypass the key ignition? How to bypass the kill switch? and how to bypass any of the other sensors to kill the spark?
i hate to answer a question with a question..
but i think i dont have a choice. so here goes.... Huh?? sorry man, but i think you need to detail your question a bit better.. i know there are lots of people on here who will def help/answer your questions.. but what exactly are you trying to do?? are trying to just get the bike running without having to use a key??? and bypass the ignision thats currently on there now. and what do you mean " you took out the plug!!" what plug did you take out?? the ignition plug? starter plug? spark plug??? theres alot of plugs :). and this is taken from the end of your question: qoute:How do I bypass the key ignition? How to bypass the kill switch? and how to bypass any of the other sensors to kill the spark? i have no idea what you mean by that.. please dont take any offence.. i write stuff on here all the time and have to go back and edit it, because i rushed and wrote my question backwards.. anyway.. just some better details and lets see if we can help you out!! jay.. :) |
when i wired up my motor the other day, i found the same thing - except i actually had my key and kill/run switch hooked up. even so - i still wasn't getting spark. we finally figured out that there was a very thick run wire (12 or 10 gauge wire that was red/yellow stripe) that needed to be hooked up to the battery as well. once i got that hooked up - i got spark. you'll have to look at your diagram for your bike - but hopefully that helps.
Thanks I got spark but now it dies when I put it in first
