Riding Skills Want to improve your skills on or off the track?
hand position questions
Old Jul 1, 2011 | 01:46 PM
Munson's Avatar
I cover the brake with 2 fingers except when droning on the highway.
Also re: hand position, I found it's a lot more comfortable to rotate the levers as far forward/down as you can, so you can cover the levers without cocking your wrists. A straight line from elbow to knuckles is much easier on your carpal tunnel and less fatiguing.
Old Jul 1, 2011 | 02:40 PM
AF Twin Turbo's Avatar
I only put my fingers on the brakes when i'm in traffic. open roads, i'm all grip.
Originally Posted by philthethrillohio
sorry but im going to have to disagree. rear brake and down shift sounds like a high side to me. you may do it well but for someone learning i would never tell em to do that. but as for fingers i treat em like my ladies no more then 2
i feel bad for your ladies. they are missin out...
Old Jul 2, 2011 | 12:26 AM
philthethrillohio's Avatar
tjink i read your post wrong , i thought you weresaying something about using your rear breaki
Old Jul 2, 2011 | 12:57 AM
f4i guy82's Avatar
thanks again fellas yea when I need to brake I grab the front with all 4 fingers, seems like I just leave the one up there so I don't forget where it's at and well 2 fingers is always enough for the clutch.
Old Jul 2, 2011 | 03:10 PM
sumone's Avatar
hmm, when I took the MSF the instructor started getting mad at me bc I would have the clutch and break covered... still not sure what the reason behind that was... but I feel much saver riding with one on each...
Old Jul 3, 2011 | 04:30 AM
Bugkiller's Avatar
July 2014 ROTM
Thumbs up Easier way to cover
Guys, just changed to shorty adjustable levers on my 1000F and what a difference! SOOOOO much easier to cover the levers without thinking about it or feeling stretched/awkward!
Best bit of kit I have bought for the bike so far
Old Jul 4, 2011 | 09:19 AM
TommyHammond's Avatar
I'm pretty new to bikes myself, and maybe I'm wrong about this, but I wouldn't be grabbing the front brake with all four fingers. Seems to me you might end up taking a flight over the handle bars.
Old Jul 4, 2011 | 12:25 PM
MadHattr059's Avatar
If you need 4 fingers to lock the front up, your brakes need work or you are riding a older model harley.
I, generally, associate anyone riding with a full grip on the throttle and no 2-finger on the brake/clutch levers as a newb. It adds several 10th's of a second to reach and respond if you don't ride that way.
At 60mph that's about 10 feet traveled per 10th, at 30mph 5 feet. That is typically the difference between a close call and catastrophe. Especially when you add in the typical 1/5 of a sec to comprehend and fire the muscles which adds another 20-25 feet closer to disaster.
So, as previously opinioned, I still think that f4i guy is best keeping that particular skill intact and should not be discouraged from always keeping a ready grip on the levers, at all times.
As for how/when on front /rear braking. In MY opinion, at any speed over about 30mph use front brakes only (the bike is going to rock forward and make rear braking negligable/hazardeous). Once you get below 30-ish and/or when the bike has settled from the initial front brake application THEN it's time for the rear brakes. Below 30mph use of both together will work pretty well, since the suspension isn't being subject to as much forward shift (generally).
As far as down-shifting simultaneous with braking, MSF has started discouraging the practice because it involoves too many co-ordinated actions to be done and STILL get maximum braking from the bike. That is NOT saying that very skilled/experienced riders can't or shouldn't use the tecnique, but all lesser riders should forgo in favor of shortest distance braking. When that includes you personally, you'll have to judge.
As Kuro has said, repeatedly, get out in an empty lot and try/practice these various techniques. Use a marker to begin each time from the same speed and you will see for yourself what we're talking about (not to mention, get that muscle memory ready for the real thing).
I hope this particular discussion helps save everyone involved some hide and money, Ern
Old Jul 4, 2011 | 12:44 PM
Kuroshio's Avatar
Yes but I still think he should use 2 fingers on the brake. The index finger is too close to the fulcrum point to provide effective braking without a lot more effort than index + middle finger. 2 fingers also provide a much more secure grip on a potentially life saving control.
As for braking practice, it doesn't hurt to do it during normal riding. Often I'll hold off longer than normal when approaching a light / stop sign before applying the brakes. I only do this on roads I know extremely well with no traffic anywhere near me. Basically I practice doing 30mph - 0mph on an almost daily basis.
And another important thing about practicing braking: you should practice it at the speeds you travel. I think it was in Nick Ienatsch's Sport Riding Techniques where he said if you ride at 120 mph you better be able to stop from 120 mph. Of course that's obviously extreme since people should only be doing 120 mph at the track (and who stops on the track? ). But it is true that you need to know how to stop from 35 mph and 55 mph.
Not just the 15 mph - 20 mph the MSF makes people stop from to pass the test.
Old Jul 4, 2011 | 02:30 PM
f4i guy82's Avatar
So I agree with this completely. I always reach up with the rest of my hand to to brake 1 finger does not cut it.
