what cm chain tensioner to get?
hey guys, i am looking at APE cam chain tensioners on ebay and they dont have the gasket with it but when i look at the knock off ones they come with a rubber gasket.
should i get the cheaper knock off ones or should i buy a genuine APE cct?
where do i find a gasket for the ape cct? i cant seem to find one anywhere online...
Timing Cam Chain Tensioner Manual Adjuster 1991 1994 CBR600F2 CBR600 CBR 600 F2 | eBay
Honda 1986 90 CBR600F 1991 94 CBR600F2 Ape HT600 Manual Cam Chain Tensioner | eBay
you use an oem gasket... or you can hi-temp silicone a gasket.
you can use either. all it is - is a bolt that presses on the guide...not that big of a deal. i would use some mild loctite or maybe even some hi-temp silicone on the actual bolt between the base and locknut- so that when you lock the lock nut down it'll seal all the way.
