thanks every1 for your help
Old Oct 13, 2007 | 11:33 AM
ze9900's Avatar
Default thanks every1 for your help
Last night I took all ofplastics off and then putthem back on. Now my bike isn't getting fuel? My pcIII isn't lighting up and my fuel pump isnt kicking on.
does anybody have any idea what Imessed up?
I have an 03 600rr if that helps.
Thanks in advance.
Old Oct 13, 2007 | 11:54 AM
vville123's Avatar
Default RE: I NEED HELP!!!
retrace your steps, backwards. something got pulled loose maybe or pinched wire?
Old Oct 13, 2007 | 12:42 PM
dizzie56's Avatar
ORIGINAL: ze9900
EVERYTHING lol.
You had to of done something besides take off your plastics. Make sure the kill switch is off, and the bike is in neutral then start going from their. Usually its something stupid like that, like you hit the kill switch by accident. Otherwise, check all the wires. You had to of done something besides just take off the plastics.
Old Oct 13, 2007 | 12:55 PM
ze9900's Avatar
i took the plastics off so i could put my old ones back on. I was planning on drilling them for my frame sliders. I got it all put back on and tried to start it and all it does is crank and its not getting any fuel. the kill switch is off (on) whichever it is. i think i have checked all of my wires but apparently i'm missing one somewhere. do you kno of any wires that i need to check specificaly (sp)
Old Oct 13, 2007 | 01:05 PM
FLYOU's Avatar
maybe your bike doesn't want frame sliders put on her? that's just my theory...
but seriously, sounds like one of your harness plugs got knocked loose or something. make sure they're all tight. make sure the PCIII is still grounded ok. maybe unplug the thing out and see if that fixes it.
same thing happened to me when i changed my oil once. you'd think an oil change would be harmless, but nope, it shorted out all my electrical stuff somehow. bike wouldn't even switch on once i put the new oil in. it was just corrosion in the front harness that needed to be cleaned.
Old Oct 13, 2007 | 03:49 PM
JonBrown's Avatar
ORIGINAL: FLYOU
yea it could just be bad timing like that. good luck finding out.
Old Oct 16, 2007 | 07:13 PM
ze9900's Avatar
Well tonight I finally fixed my bike. The bank angle sensor was cutting off my fuel. I went over every
wire and connector. Then I went through my manual and did a lil trouble shooting. I narrowed it down to
the sensor, so I hard wired the outer two wires together (read bout it in the stunter section a lil while back)
and sure enough it started right up.
Now myquestion is does any1 kno why my sensor went bad?
Well thanks every1 for your help and I appreciate it.
Now tomorrow I'll finally put my frame sliders on.
Old Oct 16, 2007 | 07:39 PM
halik008's Avatar
ORIGINAL: ze9900
you gotta reset the kill switch, rock it back and forth. did ya do that?
Old Oct 16, 2007 | 08:25 PM
isolated1523's Avatar
Retired Super Moderator
No offense, but make sure your bank angle sensor is right side up. It fits (and looks correct!) both right side up and upside down. I (as well as some other people) have done it before. Try it both ways and see if it fires up.
-Adam
Old Oct 17, 2007 | 07:19 AM
ze9900's Avatar
ORIGINAL: halik008
Yeh i reset the kill switch.
ORIGINAL: isolated1523
-Adam
No offence taken...I'll check and make sure that is not on upside down. I never would have thought about that.[sm=headbang.gif]
PhillyCBR09
Jun 5, 2012 07:14 PM
ryanm4082
May 24, 2010 03:58 PM
HrGomez
May 3, 2010 01:15 AM
Starleak
Oct 12, 2008 11:37 AM
Karl
Oct 16, 2006 10:21 PM
