Supermoto Progress... (cleaned up and "finished")
RE: Supermoto Progress...
Wouldn't ya know it...
So I've been checking tracking numbers off and on all day. Ataround 530pmthe USPS site says my camshaft had been delivered at 9 this morning... so someone has probably opened it, wondering what was inside, messed around with it, let their kids play with it... blah blah blah I get to wait another week or so to get the thing installed.
So after all was said and done I check my mailboax today and there sat my missing package. The top flap had been worked over pretty good, someone was trying to thumb around and see what was in it. When they failed, they must have brought it to my house.
Anyway, the cam was undamaged and I'm getting ready to go out and start fiddling with some stuff. I'm going to shoot some video of the bike idling before and after just to kind of be able to compare them back to back. Front fender didn't show up, grrr.
Oh well, if I've got parts sitting around that means I'm behind. I'll take some pics of the cam swap I guess, not sure anyone cares about a cam...
Alright, got a quick question...
Getting ready to install the cam.
OEM valve clearances (lash)are;
Intake: 0.0032-0.0048
Exhaust: 0.0042-0.0058
Racing cam clearances are;
Intake: 0.004
Exhaust: 0.006
So... I just adjusted the valves the other night with a buddy. They weren't bad, but we adjusted them to within spec. And we stayed on the low-side so intake is about .004 and exhaust is about .005 - so here's my question...
Everything seems to be just a bolt-on, literally, at this point. I was expecting to adjust the valves for the new cam but it would appear that I'm already at target lash. Any input on this possible myth?
The only reason I'm even asking I guess is because my feeler gauges are too thick, they start at .008. So anyway, just kind of curious if this is somewhat normal or maybe just an anomoly in which I'm being paranoid (and impatient).
I really shouldn't go out in the garage to do this because I know I'm going to fire it up when I'm done...
Intake: 0.004
Exhaust: 0.006
After reading what I wrote I'm thinking that I should wait - if my exhaust clearance is currently .005 it would not provide adequate clearance as the minimum lash for the racing cam is .006... right?
The number can be bigger, but not smaller, right? Better wait till I get some new feelers tomorrow...
ORIGINAL: KidCr3nshaw
I really shouldn't...I know I'm going to...
If I had a dollar for every time I've said that...actually, no, if I could have back all the money that I spent after saying that...
And sorry Kid, there's probably only two other people on the board that even know what a gauge feeler is--and I'm not one of them. Sure is exciting to see what you're doin' with this, though.
I just adjusted the valves on a Suzuki Bandit this weekend, all 16 of 'em. The thing with valve clearances are, if they are a little wider than spec, you get valve chatter. If they are narrower, you'll get burnt/warped valves, interference between the valve and piston and generally terrible things.
When I adjust valves I set them to the middle of the range if not the bigger end. Valve clearances tighten with time, its not too likely that you'll ever have too loose of a valve clearance unless somebody did a ****ty job adjusting them before. The reason is the valve seats further into the head as the engine breaks in and wears. So that causes your clearances to get tighter, and like I said if you don't adjust them then you'll end up screwing up your valves or the entire engine if it goes for too long.
