How Does A "Adjustable" Steering Damper Work?
Old Nov 22, 2010 | 10:01 AM
__Z__'s Avatar
April 2011 Ride of the Month
Default How Does A "Adjustable" Steering Damper Work?
Van is giving me a gsxr damper for my 929 (to fiddle with)
and of course i did something dangerous and started thinking.... if you removed the allen screw from the damper, screwed in a 90deg. brass fitting, off that fitting screw in a small stainless line on the other side....
then take a small piece of aluminum and drilled a hole in it/thread it then... screw a brass nipple on one side to attach your braided line...
then put a allen screw or any screw/bolt on the other side haven't you in fact just made a stock damper "adjustable" by filling the entire thing with whatever weight oil, then turning the allen screw in or out you would be adjusting the pressure inside the damper....
wouldn't this work? not that i really care im just needlessly rambling
Old Nov 22, 2010 | 10:24 AM
__Z__'s Avatar
lol see this is what happens when i get bored.... on and you could even throw a t fitting in there and run a pressure gauge so you can know what your "adjusted" to
Old Nov 22, 2010 | 12:10 PM
DetroitF4i's Avatar
No idea how if this would work, but you can write an app that lets you see the pressure that you are adjusted to on your phone, right from the comfort of your home
Soniclight
F2 Tech
Jun 18, 2013 11:34 PM
mrsmobbins101
Apr 1, 2013 11:07 AM
jun167
Sep 3, 2009 06:06 PM
KenG
CBR1000F For Sale / Found
Aug 9, 2009 05:20 AM
