damn chains.....
ok so i am looking for a new chain and sprocket set for my baby and i was looking around at the different chains offered and i was just wondering if any of yall had an opinion as to which chain you preffer... i was looking at either an ek chain or a did..... also i am getting vortex front and rear sprockets but i cant remember how many teeth are on the front and rear sprockets... any opinions and advice is greatly appreciated......
edit: also should i get an x-ring or an o-ring?
2nd edit: also should i get a 520 conversion kit?
i cant stop editing!!!!!!!!!!!!!!!!!!!!! hahahaha
as i understand it the x ring will last you longer and is "tougher" , the "o" ring however is a more budget friendly choice. i have a "DID" 520 with vortex sprockets on my 9RR. but i could swear that i remember hearing that if you go with a 520 conversionit will affect your speedo like gearing will, so you might want to look into aspeedo healer as well.
Hmmm...I'm only assuming the OEM sprocket sizes are the same on mine (07) as yours and it's 16/42
I wouldn't waste more money on an X-ring chain though. All the O and X ring does is help seal oil in and dirt out. I'd stick with an O ring DID or RK, bothare top shelf.
As far as the 520, that's up to you. Less weight, but not as strong as a 530 which is stock now.
thanks for the tooth count and the only reason i want an x-ring chain is because it is about 50 bucks cheaper than an o-ring so im probably gonna go ahead and get the o-ring...... whats 50 bucks right lol
I have an RK x-ring on my F2 and as little as I have gotten to ride it recently, I still think it was a good move. Check www.indysuperbikes.com to see if they have what you are looking for.
