$55 + tax to install Chain & Sprocket kit
This is a *DIY* project. Estate, you can do this. :-)
Follow this tutorial...https://cbrforum.com/forum/how-mecha...et-swap-97641/
Buy the Stockton Tool chain kit from CycleGear for $39 & it will pay for itself w/ the first job. STOCKTON TOOL COMPANY Parts & Accessories - Chain Breaker and Rivet Tool Kit - Cycle Gear
If you do have your mechanic do this, be sure to double check the flare spec on the master-link pins. <-This is often done incorrectly. Also be sure to check that the flare(s) are not cracked. If they are, the master-link needs to be replaced & redone.
bowtieboy42
F2 Tech
07-10-2012 03:53 PM
