10% ethanol
Old Sep 21, 2008 | 02:44 AM
  #21
kamikaze2899's Avatar
Default RE: 10% ethanol
ORIGINAL: vpsophmore
So if they're putting 10% ethanol in at the pump, are getting gas 10% cheaper/gal than the stations who don't use it?
Nope gas prices stay the same no matter what you run. Ethanol is more expensive to produce, but is not as efficient as standard gasoline. So it actually causes you to burn more to get the same power. Prior to going to E-10 I was getting 18-20 miles per gallon out of Mercury Marauder with no mods except for an intake, and exhaust. After going to E-10 I averaged 14-17 miles per gallon. Same brand, station, and driving style.
As for the marine applications, if your fiberglass fuel tank was made with polyester resin, then the ethanol would eat it up turning it into a jelly. When it went through the fuel system it instantly varnished everything clogged filters and injectors. Also because it mixes with water so readily, the standard fuel water separators couldn't do their job, and let lots into the engine screwing things up. Small engines like weed whackers and lawn mowers suffer because you hardly ever use the whole tank of fuel, also your fuel cans sit for long periods of time. Ethanol goes bad within a few months.
As you can tell, I really really don't like ethanol.
subyman1440
Nov 11, 2012 08:28 PM
cbrf4ikid0902
Apr 5, 2010 10:13 PM
fast1000f
Mar 26, 2009 08:05 AM
SeattleSy#1255
Jul 6, 2007 01:08 AM
Jaybird180
Jun 10, 2006 01:05 AM
