Thanks for letting me join....I have a problem with my 1999 CBR600 F4
Old Jan 23, 2011 | 02:58 PM
georgee1poorgee's Avatar
Default Thanks for letting me join....I have a problem with my 1999 CBR600 F4
Thanks for reading my post. I just bought a used bike. I was on my way to work and my bike just died on me on the freeway. Like if it wasn't getting any gas. It cranks over but, doesn't start up. Could this be my fuel pump?
Old Jan 23, 2011 | 03:13 PM
backyardmechanic's Avatar
It could be fuel pump or regulator, sparks, lines, fuses or the screen in the tank being clogged. i would give a good once over to all the wiring and fuel lines
Old Jan 23, 2011 | 03:31 PM
The day before this happened my bike was bogging out on my way to work. When I went home it ran just fine.
Old Jan 23, 2011 | 05:15 PM
man its hard to tell, how old are the sparks and is it the original fuel regulator? if the sparks are worn out change em and i would change the reg if your not sure when its been changed last.
Old Jan 23, 2011 | 07:34 PM
Turbulenz's Avatar
Official Welcome Crew
Could be a pump... could be teh pump relay... maybe fuel filter but not likely.. last year my F4 did that.. would shut off like it was out of gas.. turned out to be the fuel pump.
Easy fix
Old Jan 23, 2011 | 07:39 PM
Thanks guys, that's helpful. I'll try some of the suggestions and hopefully it's something easy and not too expensive.
Old Jan 24, 2011 | 02:32 PM
So I just took off the hose going from the fuel pump to the carbs and turned the key and shot some gas out but, when I try starting it, it doesn't shoot any gas out at all. Is that normal?
Pinoyisme
Oct 1, 2010 05:46 PM
simoniz
Aug 23, 2009 12:12 PM
GUSHANAS
May 14, 2007 02:09 PM
