Love my F4i
Old May 14, 2013 | 12:36 AM
CP49's Avatar
New Member
Default Love my F4i
Hey guys! I've got a 2001 600 F4i that I've been working on and riding. It's my first bike and loving every minute of it. It does need a new fork seal though and I'm a little nervous about doing it myself. We'll see how it goes.
Old May 14, 2013 | 03:40 AM
wheelnut's Avatar
Welcome Crew
hi and welcome
if you decide to do the fork seal, just take your time and if you run into problems there is always someone on here to help you out
Old May 14, 2013 | 04:52 AM
Turbulenz's Avatar
Official Welcome Crew
Welcome! You made a great choice with the F4i
Old May 14, 2013 | 04:38 PM
Conrice's Avatar
welcome to CBRF! replacing a fork seal on a conventional fork is not too difficult.
here's a vid
part 1
part 2
part 3
the vid makes it easy.... hope that helps. it's been a while since i watched that video, so i don't know if he touched on this or not. make sure you keep everything clean. make sure there isn't sand or dirt on any parts (washers, spacers, springs, etc.). also, go slowly getting the top cap back on. there is going to be a lot of pressure putting that cap on, but don't put too much force on it - once you get the cap started, it should thread/screw in very easily. if it doesn't, start over - you don't want to cross thread it
Old May 14, 2013 | 05:19 PM
CP49's Avatar
New Member
Haha thanks for all the advice. I'll let you know how it goes
Old May 14, 2013 | 05:30 PM
74demon's Avatar
Fork seals are easy. It can be a scary job the first time though. The hardest part is getting the front end off the ground and the forks off the bike. That's even pretty easy. Make sure you find out WHY they leaked. The tubes could be bent, scratched, or pitted. The bushings inside will tell the tale. You may just have old seals in there that gave up.
You may want to consider replacing the springs and valves too. They were set up for a light rider and they do lose their spring when the get old.
Read threads and the manual to get to know the procedure, and you'll be fine.
Good luck and welcome.
Where are you located?
Old May 14, 2013 | 05:51 PM
Sebastionbear1's Avatar
Welcome to the CBR Forum,
Good luck with the seals.
Cheers, SB
MadDogMcQ
May 28, 2011 02:50 PM
mitsokid
Sep 15, 2010 12:45 PM
dcaldwell
Sep 7, 2010 10:12 PM
hawkwind
The Hurricane Saloon
Apr 23, 2009 12:43 PM
Saved_one
Sep 5, 2006 02:44 PM
