I知 stuck!!
Old Feb 7, 2021 | 11:34 PM
Mikeporter's Avatar
Default I知 stuck!!
So I知 trying to rebuild my clutch in my f3. But my inner hub will not budge. Do you have to remove the center nut? Any tricks you guys have to remove this? Any help is appreciated
Old Feb 9, 2021 | 12:52 PM
chris0986's Avatar
would you please give some pics? I don't own a f3, but I do have some mechanical experience which might help you.
Old Feb 15, 2021 | 10:50 PM
SunBlue's Avatar
what does your service manual say?
On my F4i you have to remove the center nut to remove inner/outer baskets. Clutch holder helps, so does an impact
Old Feb 17, 2021 | 06:53 AM
Mikeporter's Avatar
I have no service manual. Haven稚 had the bike very long, so I知 new. I watched several videos and none of them had to remove that bolt.
It just made sense to remove. I used an impact and boom! That was it.
Old Feb 17, 2021 | 01:25 PM
The clutch center lock nut is "staked" over so it doesn't come lose on its own. It needs to be "unstaked" and then removed in order to remove the clutch center, discs and plates.
Old Feb 17, 2021 | 04:55 PM
To add on to this, there is a Sticky with the manual in it in the F3 section.
Old Feb 17, 2021 | 07:32 PM
SunBlue's Avatar
Glad you got it sorted out!
I've never had to unstake it when removing with an impact.
Remember to get a brand new nut and stake it in the correct direction!
Sea Bear
Apr 1, 2019 11:54 PM
lepy
Apr 17, 2012 10:09 PM
hondaben420
Jul 9, 2011 01:41 PM
Smoffler
F2 Tech
May 8, 2011 10:51 AM
wiseRR
Feb 27, 2011 10:37 PM
