Clutch help
Old May 4, 2011 | 11:58 PM
Smoffler's Avatar
Default Clutch help
Trying to get the hub off so I can remove the basket, any ideas?
Old May 5, 2011 | 09:10 AM
jtkardel's Avatar
So you have the nut off right? It often takes a ton of force to pull the clutch basket off the countershaft/output shaft (i'm not sure which one it is in this situation. Hitting the shaft lightly with a rubber mallet while trying to pull the basket off should do the job. After all that use, you get a bit of a friction fit.
Old May 5, 2011 | 10:05 AM
Smoffler's Avatar
No, I need to get the nut off it's being a pain in the ***
Old May 5, 2011 | 11:38 AM
JesseAwesome's Avatar
Air Impact wrench
Old May 5, 2011 | 01:17 PM
jtkardel's Avatar
Air impact works, also a clutch basket holder tool will work. Those are cheap, $30 or so.
Old May 5, 2011 | 01:39 PM
DagonRais's Avatar
Impact wrench. Its useable for other things besides just a clutch. All dependent that you have an air compressor though
Old May 5, 2011 | 02:27 PM
Harbor freight. $120 for a decent one that will more than do the trick for small jobs, seating tires, inflating care tires, etc etc etc.
Old May 5, 2011 | 02:52 PM
Smoffler's Avatar
Okay now I gotta remove the basket haha I used an impact btw now how do I remove the basket and all goodies behind it?
Old May 6, 2011 | 01:20 AM
buickid's Avatar
Harbor Freight sells a decent electric impact wrench that works well for occasional use too.
Old May 7, 2011 | 10:54 AM
jtkardel's Avatar
Here's the relevant section from the manual.
