Help required! No ignition lights!
Hi, just registered in the hope someone can get me back on the road!
Just went to pull the old girl out of winter storage (not the wife) and as soon as i turn the ignition on all the dash lights went out and nothing.
Have checked all the fuses (that i can find) and all ok?
Is there a hidden fuse i cant find or does this one finally go the the breakers? any help would be much apreciated!
oh yeah, its a 1990 cbr 1000f, that info may be helpful.
cheers, Chris
cheers, Chris
hey chris... there is a lot of 1000f owners here and if you go to past cbrs section it will be the first one listed. post all your questions there and they should be answered.
welcome to CBRF.
welcome to CBRF.
Hi Staffy
Not sure if this will help you but it might point you in the right direction..
All fuses except the main fuse are located in the fuse box behind the left upper fairing inner section, The main fuse however is fitted to the starter relay which is behind the right side panel.
Check it out - sounds like main fuse is gone.
check your battery and connections too
Good lUck
Good lUck
