Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
Rear psi required?
Old Nov 28, 2007 | 11:32 AM
Nauree's Avatar
Default Rear psi required?
Is it necessary to drop your psi in the back? I'm running my my psi for turns which I do more of but I want to learn to wheele better. I'm having trouble hitting the bp and I think its because of a physcological factor. I keep telling myself its not good trying to wheele at 41 psi.
Old Nov 28, 2007 | 11:40 AM
DThompson's Avatar
Default RE: Rear psi required?
haha, you can wheelie at whatever PSI you want to but it will be easier to do it at a lower psi. See if you are riding with high pressure than you only have about a 1" or 2" block of space that you are actually resting on, The lower the PSI the bigger the amount of space you are resting on.
It just makes it easier, but dont forget to fill your tires back up when you take some twisties.
Just for reference I run at about 13-15 psi when im stunting and maybe 20 on the highway.
Old Nov 28, 2007 | 01:40 PM
Nauree's Avatar
Also, whats the best way to learn stand ups? I been doing first gear sit downs and I tryed doing a first gear stand up. Idk how to bring it up while standing.
Old Nov 28, 2007 | 02:02 PM
jlh077464's Avatar
Well i can tell you putting your left foot on your back peg makes a world of diffrence when first pulling it up. Also shifting weight and kind of like a bounce, push down on the bars and pull up on them while giving it more throttle. Now that might not be how it is suppose to be done, it just worked for me, oh and we have the same bike , even same color scheme.
Old Nov 28, 2007 | 02:24 PM
Nauree's Avatar
Should I even clutch it when trying to do stand ups in first? I tryed it one time and it threw me into the handle bars and I kinda landed hard. I quit doing them after that.
Old Nov 28, 2007 | 04:21 PM
sixshooter989's Avatar
You should be doing 2nd gear,it's way smoother. Throttle is very touchy in first.and there is alot of engine braking. 2nd gear goes up smooth,and comes down smooth.
Old Nov 28, 2007 | 11:09 PM
DThompson's Avatar
Do me a favor and dont even try standing up until you are good at doing sit downs.
Im only saying this so you dont flip your bike over.
Old Nov 29, 2007 | 12:12 AM
OC's Avatar
OC
ORIGINAL: Nauree
IMHO you shouldn't be trying corners at 41 PSI. Somewhere in the lower 30s would be much better. Keep in mind it all depends on the bike, tires, weight, and conditions. The motorcycle mags wont even suggest a pressure, they just say find what works for you. So don't take this as me saying 41 PSI is wrong, just that I would suggest a lower pressure for aggresive cornering.
Old Nov 29, 2007 | 09:07 AM
Compton82's Avatar
I run 20-25 psi
Old Jan 8, 2008 | 08:46 PM
yarbrouc's Avatar
25 in the front and 20 in the rear. Tires will go faster but hey your going to brake alot of stuff and spend alot of money eventually
chrisrc
Jul 20, 2010 10:28 PM
Bordo
Sep 23, 2009 08:46 AM
Bon
Apr 27, 2009 11:10 AM
xvfrona
Dec 20, 2007 05:02 AM
