Battery Problem
Old Jun 23, 2010 | 10:35 AM
MegatronousPrime's Avatar
Default Battery Problem
can anyone tell me if ur battery can die on 94 cbr600 if u leave the bike idling for too long?? Here is the situation: Started my bike and left it runnong for about 15 minutes and the bike just shut off completeley. Then, my dumb *** jump started it with my car battery while my car was running..(a freind told me i did a baaaad thing)and the bike started and shut off again after like 5 minutes... What do u guys think??? Should i buy a new battery??? please help... I'm a new rider, just started riding this week.
Old Jun 23, 2010 | 10:45 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
It sounds like the charging system is not working. The battery should not drain if the bike is running. You could try connecting it to a trickle charger for a day and see if it brings it back up to fully charged. A Battery Tender Jr is less than $25 off eBay, including shipping.
How old is the battery? You said it's a '94 year bike. You can test the charging system by measuring the voltage at the battery when it is off. Should be 12+ volts. When the engine is running it should go up to 13-14 volts.
Edit: You can jump start off a car battery safely as long as the car is not running or you risk doing damage to the bike's electrical system.
Old Jun 23, 2010 | 12:39 PM
RoadiJeff's Avatar
You can use this helpful guide to futher troubleshoot your charging system:
How to Diagnose Electrical System Issues on Motorcycles
Old Jun 23, 2010 | 04:50 PM
Kuroshio's Avatar
If the battery is weak it'll die while idling. The stator doesn't really kick in till about 4.5k rpm.
Old Jun 23, 2010 | 05:07 PM
Goloth's Avatar
Check your electrical system with that diagnostic roadijeff linked, could be your stator, r/r, coils, several things, and it's possible you shorted your ENTIRE wiring harness jumping that thing with a started car, that's usually VEEEEERY bad, don't wanna worry you man, but I wish you luck.
Old Jun 24, 2010 | 08:58 AM
Default Battery problem
Hey thanks for all the advice guys, and I am happy to find out that it was just the battery--it did not have enough Juice. And nothing was damaged i guess since the bike started rite up with the new battery......
Old Jun 25, 2010 | 09:41 PM
kilgoretrout's Avatar
Administrator - Retired
Yep, a battery can discharge from idling as you've found out... lol.
Welcome to the forum, man.
caddylicious
Dec 9, 2009 07:32 PM
cjmccart13
Apr 1, 2009 04:08 PM
oldschoolCBR
Mar 5, 2007 11:21 AM
cbrdaddy96
May 18, 2006 09:55 PM
kobester
Jan 10, 2006 10:43 AM
