1992 Honda CBR600 F2 low compression
Old Apr 5, 2020 | 12:44 PM
Luke Stein's Avatar
New Member
Default 1992 Honda CBR600 F2 low compression
I bought a totaled f2 engine and wiring harness, and thought it would be a good idea to put it into a quad, built the frame, all the wiring, now finally a test drive. It seems as cylinder 2 is not doing a whole lot, not pulling the diaphragm open on the carb when it is reved up. Compression test says 150, could it be a stuck valve? Maybe rings? And advice on what to do next would be greatly appreciated.
Old Apr 5, 2020 | 12:50 PM
74demon's Avatar
Wet compression test would be next.
Did you check the valve clearance to see if any are tight?
Bear600rr
Dec 10, 2008 07:23 PM
bms
Nov 3, 2007 09:04 PM
MT Wallet
Jul 24, 2006 05:03 PM
