05 600RR battery dying, after battery and regulator replacement
Old Dec 20, 2024 | 04:20 AM
Travel600RR's Avatar
Default 05 600RR battery dying, after battery and regulator replacement
As the title says.
Im the second owner of a 05' CBR600RR. I keep it on a tender when I'm not using it.
I replaced the battery and regulator, but my battery is still dying after a few hours. Because it's on a tender before I check, Resting is low 13V, when the bike is running it was high 13V and rising, which I'd think would mean the reg is operating correctly.
Now what do I check? I'm a newbie motorcycle mechanic, but I do car repairs and I'm an electrician. When do I throw in the towel and just take it to a mechanic?
Side question, I also saw green fluid in the bottom farring when I was replacing the reg, I believe it's radiator fluid (coolant?). Can I use traditional radiator stop leak in my bike or is there a special kind of is this another repair?
Old Dec 20, 2024 | 07:30 AM
rockpool's Avatar
Don't use any stop-leak, find where the leak is and fix it properly -. the water passages on a bike are much smaller than a car an stop leak can easily block them up.
You should be getting over 14v at 3000rpm. Grab the service manual for the bike - it usually has a full electrical troubleshooting section.
https://us.haynes.com/products/honda...46929915543802
null84
Dec 9, 2007 09:36 AM
keithacole
Aug 7, 2007 10:48 PM
Knertified
Aug 2, 2006 02:29 PM
silentassassin
Mar 6, 2006 08:11 PM
MarkHutch
Nov 6, 2005 09:45 PM
