Oh no...another rattle thread
Old Feb 24, 2020 | 12:46 AM
DSA's Avatar
DSA
Default Oh no...another rattle thread
Old Feb 25, 2020 | 09:31 AM
Sebastionbear1's Avatar
If it is not cam chain, then it's most likely alternator chain. Video was not long enough nor clear enough to hear the rattle.
Cheers, SB
Old Feb 25, 2020 | 10:33 AM
DSA's Avatar
DSA
Thanks, I'll shoot a better one this weekend.
If it IS the alternator chain, looks like I'd have to split the cases to fix it. Is this a benign rattle, where it's just an inconvenience but won't cause any serious damage? Or is it likely to give out some day?
Old Feb 26, 2020 | 01:56 PM
DSA's Avatar
DSA
Thanks!
Old Feb 27, 2020 | 04:30 PM
Antti Suonio's Avatar
To me it sounds like the CCT. If it fails it will rattle at all temperatures and not just when warming up.
Old Feb 27, 2020 | 06:15 PM
DSA's Avatar
DSA
Thanks for the input. If it is indeed the CCT, from what I'm reading on the forum, there shouldn't be any danger if I can't attend to it immediately, right? It's not causing something else to wear, nor is it going to suddenly snap or jump and throw off timing. It's mostly just the annoyance if hearing it rattle, correct?
Old Feb 28, 2020 | 04:28 AM
If it is badly worn/broken it can cause the chain to be so loose that it skips timing and will bend a valve. It is normal to have some noise when warming up but if yours is constantly noticeable I'd get it fixed asap. Not 100% sure if it is your CCT but thats probably where I'd start.
Old Mar 1, 2020 | 02:46 PM
It certainly sounds like the CBR1000F dreaded timing chain rattle. Plenty of info on the site on how to change it, one of the best by Naga Thai if I remember correctly.
EDIT: Here's the link https://cbrforum.com/forum/how-tos-8...a-thai-143024/
Cheers, SB
Old Mar 1, 2020 | 07:07 PM
DSA's Avatar
DSA
Old Mar 3, 2020 | 12:38 AM
DSA's Avatar
DSA
Hmm so I turned the crank manually and took measurements every inch or so down the length of the chain. It is definitely slacker in some places (between 2 and 3 mm if travel at the center) than others (barely any motion at all). This doesn't necessarily mean the CCT is at fault, because I assume the CCT can't do its job properly until the engine is on and oil pressure builds.
dano_seattle
May 21, 2010 11:43 AM
mauthman
May 27, 2008 06:08 PM
G3NESYS
Mar 26, 2008 09:09 PM
michnet76
Feb 15, 2008 01:51 AM
chpsk8er630
Apr 23, 2007 05:46 AM
