I am out of ideas :icon_cry:
#101
#102
There were so may replies I only read about half, but I had very similar problems. If this is a duplicate reply, please forgive me.
When I bought my 96 Cal, mod. the tank was a mess, really bad rust. During the cleaning process I got a handful of rust chips out of the tank. I took the carbs off a second time and crap was in them and blocking 2 pilot jets, let me jump to the end, 5th removel, washed all passages out with 2 cans of carb spray. I found that compressed air would not remove very much debris, carb spray would "wash" it out.
U have to check the pilots very carefully, it is very difficult to tell if blocked because of their size,
U said u balanced the carbs, does that mean u synronized them? U also said that it wouldn't idle, and U can't syncro them in that case.
If any of this sounds like it may be ur problem let me know and I can fill in the details, because there was a LOT more to the cleaning process.
#105
#106
Guest
Posts: n/a
No doubt your fuel and the chit in your tank set this off ...
but , I don't think we forgot anything Pablo ...
In your very first post you mentioned that you had checked the plugs ..
I recon the incorrect firing issue began right then and there mate ..
Two plugs are fine one, is way lean, and one is gas fouled. I don't know what to do anymore. Any ideas? Thanks
#108
