wiring order of the rectfier to loom plug
hi chaps
bought an electrix world rectfier
i got two plugs with it as thee oem one's were burnt. can somebody show me pic of wiring order going from rectfier to loom plug please.
Greetings and Salutations!!!
Which year bike?
Please post photos of RR's plugs and sockets you have on harness.
Might be simple case of chopping off connectors on one side and install
matching ones on other.
Which year bike?
One thing to remember with these connections to the reg/rec, is that they must be 100% secure.
There's a lot of electrical current coming up those yellow wires from the alternator, and if there's a connector that's not fully home, then burn-out and sometimes fire, is just around the corner!
Unfortunately you can't see inside the six pin when it's closed, so check everything closely beforehand.
I've got an ElectrexWorld reg/rec in my bike. It supplies more current to the battery at low revs, which helps with a bike that's not ridden everyday.
Cheers
Cheers
There's only one for all models of CBR1000F - https://www.electrexworld.co.uk/cgi-...2Ehtml#SID=439
The colors match between the bike harness and the rectifier - black to black, red to red, white to white, and yellow to yellow (yellow order doesn't matter).
That connector certainly let all the magic smoke out. I think this is the right replacement - https://www.ebay.com/itm/25499291486...xoCGP4QAvD_BwE
MadisonD
Aug 2, 2010 06:52 PM
