How To's Show us what ya did and how ya did it!
Fork Seal - Replacement
Old Dec 27, 2009 | 04:58 PM
Naga_Thai's Avatar
Default Fork Seal - Replacement
In addition to the great advise already written by members who have done this - here are my additional photos & tips...
2 x Honda Fork Seal Kits as below in Australia = $76.50
Oil = $29.00
Attached Thumbnails Fork Seal - Replacement-img_3517.jpg   Fork Seal - Replacement-img_3524.jpg   Fork Seal - Replacement-fork-seal-set-one-oil-seal-one-dust-seal.jpg   Fork Seal - Replacement-img_3526.jpg   Fork Seal - Replacement-top.bmp.jpg
Old Dec 27, 2009 | 05:15 PM
Naga_Thai's Avatar
1 Bike on centre stand and jack or block under sump for support. Support brakes with ties.
2 Unscrew Cap from top bolt (Outer of Tubular spanner in toolkit fits CAP).
3 Fully loosen top bolt before removing stepped collar clip.
4 Top and lower bushes only need replacing if all the teflon (grey color) is worn off and you clearly see all copper color. You can see good teflon this bottom bush. The top bush is also OK because the teflon is on the inside (the working surface). If these need replacing = $15 each in Aust.
Attached Thumbnails Fork Seal - Replacement-img_3527.jpg   Fork Seal - Replacement-img_3529.jpg   Fork Seal - Replacement-img_3533.jpg   Fork Seal - Replacement-28-12-2009-10-07-13-am.jpg
Old Dec 27, 2009 | 05:17 PM
Naga_Thai's Avatar
When tapping in the new seal PLACE THE OLD SEAL ON TOP OF THE NEW SEAL then tap in place with the PVC pipe. This further protects the new seal.
In Australia the PVC pipe can be bought from Bunnings - part - PVC PRESSURE PIPE HOLMAN 40MM 1MTRE LONG PVP4012-1 for $9.24. This pipe will fit exactly and you dont have to cut as in picture 1 here.
Attached Thumbnails Fork Seal - Replacement-forkseal-step8-lg.jpg   Fork Seal - Replacement-holman-pressure-pipe-pvp4012.jpg
Old Jan 19, 2010 | 11:34 PM
Trips's Avatar
Just a note.
Dont just buy new bushes thinking they will do the job. You need to check the wear on the inside of the fork leg to make sure you dont need a (custom) oversized bush.
Old Jan 23, 2010 | 02:59 PM
Barto's Avatar
Default front suspension height
On my 91' my front suspension sits considerably lower than the suspension on my buddies 90'. Is mine at the wrong height? Is this something adjustable or is it diferent because of the model year difference?
Old Jan 24, 2010 | 10:07 AM
Boab's Avatar
I changed the springs in mine, now have Hagon progressive springs. What a difference it has made. Taken away the sag and stiffened the front end up a bit.
Old Mar 30, 2010 | 10:41 AM
WhiteHawk's Avatar
Its nice to have an impact wrench to work that bottom hex head bolt (where the wheel axle sits). Also, while you're in there, check out Race Tech Suspension for some new higher rate front springs (pretty affordable), I think they stock bushings and seals too. I've replaced the springs with these while servicing the forks on my 87' 1kf and my current 95' 1kf. Especially if your springs are a little rusty, then you should really get new springs (rust is detrimental to fatigue life, was a valve spring engineer; fork springs are just really long valve springs lol).
Old Aug 11, 2013 | 06:32 AM
turbo787's Avatar
Hello guys...just wondering about the ammount of oil that's supposed to go into each fork tube? in oz.? Will be doing it again in the near future but never knew how much is really needed...Thanks for the help!!!!!
617rider
Mar 17, 2014 01:22 PM
DDME
Mar 9, 2012 09:49 AM
bobmilkman
May 25, 2010 10:51 AM
lptwist
Jun 22, 2008 11:34 AM
wildzx6
Jun 21, 2008 06:03 PM
