How To's Show us what ya did and how ya did it!
Coolant Flush
Old Jul 15, 2012 | 06:55 AM
jlpinedas's Avatar
Post Coolant Flush
Make sure you park it (Use the center stand) where it does not matter where it'll do a mess.
1. On the left side of your bike at the water pump there is a drain plug (See pic 1 - I already removed it here)2. One that's removed, place a container about 2 feet away from it. Remove the radiator cap the you'll see the coolant come out.3. As for the coolant reservoir, i used a manual sump pump that i got at Harbor Freight to suck out the coolant in it.
4. Put back in the drain plug. At the radiator cap fill it with distill water, all the way up to the neck, then fill with distill water the coolant reservoir up to the upper level line.
5. Run bike for 10 min.
6. LET IT COOL OFF before proceeding with the steps below; otherwise, you'll get burn as the water gets EXTREMELY hot.
7. ONCE COOL OFF. Remove drain plug again. Remove Radiator cap preferable with a towel, just in case it's not too cool off. You don't want steam on your face.
8. Repeat steps 4,5,6,7 again
9. Make sure you don't see the distil water coming out with coolant residual. If it still does then you can put more water in it to rinse it out. This is not really necessary but i'm very meticulous when it comes to details. LOL
th_IMG_3431.jpg?t=1342352007
10. Repeat step 3
11. Plug in the drain plug, Fill in coolant from the radiator cap up to the filing neck. Place the radiator cap back in. Fill in reservoir coolant tank up to the upper level line.
Old Jul 15, 2012 | 03:10 PM
Sprock's Avatar
you forgot 12 - replace empty liquid refreshment of choice for new one
nice and simple - well done
Old Jul 15, 2012 | 06:35 PM
jlpinedas's Avatar
I knew I was forgetting something. I went out for victory dinner once I was done.
Old Jul 15, 2012 | 06:57 PM
MadHattr059's Avatar
Ditto Sprock's comment. I like seeing the KISS principle in action. ;-)
Ern
Old Jul 16, 2012 | 04:46 AM
Bordo's Avatar
Good job mate. After I do a coolant change I check it over the next few days to ensure the level stays correct. Air can sometimes remain in the system and the level can drop a little bit once it works its way out. I've only ever had to top up a little bit a couple of times.
Old Jul 16, 2012 | 03:57 PM
jlpinedas's Avatar
@ MadHattr059: KISS principle?? Sorry but never heard that before and i'd like to learn a new lingo...
@Bordo: Thanks for the info. I never done a coolant flush before. I will make sure to check today once i get home.
Old Jul 16, 2012 | 04:08 PM
gotcbr's Avatar
Originally Posted by jlpinedas
...KISS principle?? Sorry but never heard that before and i'd like to learn a new lingo...
Keep It Simple Stupid ;-)
or
Keep It Short & Simple
Old Jul 16, 2012 | 10:18 PM
jlpinedas's Avatar
KISS principle is the best way to go!!!
bluej511
How-To: Mechanical
Mar 20, 2014 09:51 PM
05f4ii
Feb 7, 2014 10:43 PM
zbake
Feb 23, 2013 11:09 PM
NE1000F
Jan 5, 2010 03:27 PM
04_CBR
Jun 9, 2008 01:08 PM
