How To's Show us what ya did and how ya did it!
Cam Chain & Tensioner Replacement
Old Apr 26, 2011 | 03:55 AM
  #51
HenryM's Avatar
Don't go breaking that primary chain Pete. I know you didn't mean that!!!
Could mean a bit more than fixing the whole effing lump if it gets trapped on the crankshaft when it goes bang. I shat myself at the thought of that when my tensioner collapsed.
Anyway, I need to do what you're saying too, just for good measure. She's running well, not too noisy from the cam chain most of the time.
What I"m really looking forward to though is rebuilding the head and changing the gasket, possibly new rings or a rebore if needed. That'll make a big big difference. Still got that damned ticking noise since the last major rebuild, but after more than 20K miles it hasn't got any worse so I'm not worried about mechanical failure, it's just bloody annoying.
You must have a very sound proof helmet. Mine doesn't really make much difference.
Ah well.... Keep safe mate. Must catch up on Skype soon.
Old May 31, 2011 | 12:42 AM
  #52
starturbo's Avatar
Registered Users
Brilliant write up and fantastic pictures.Well done!!
One question is how do you know if the chain needs replacing? I need to replace my tensioner because it's rattling like a skeleton in a filing cabinet,masterbating like mad.
I would rather just do the tensioner given the choice.
Old May 31, 2011 | 08:19 AM
  #53
roughseas's Avatar
This thread rocks! I have an K model which is plagued by the rattle, thought it was the cam chain and went and replaced the tensioner... turns out it wasn't the cam chain/tensioner, so guessing the starter damper needs a fix.
Rattle only below 3k revs, hot or cold. Has anyone had bearing failure at the alternator? I do have a major starting problem, if she doesnt fire on the first crank she wont fire at all on the starter and the alternator wiring connectors look little melted. 28k kms on the clock.
Old May 31, 2011 | 09:08 AM
  #54
Shadow's Avatar
Probably not
The damper doesn't ever cause a rattle -
- more likely to be the primary chain tensioner
To replace it is an engine out job - no other way.
It helps if your carbs are sync'd and clean - the rattle is partly caused by the "whip" in the chains - THIS APPLIES TO CAM AND PRIMARY CHAINS.
Seafoam in the tank also helps
And no, I've not heard of a stator bearing giving up - they run in oil after all.....
Quote : I have an K model which is plagued by the rattle, thought it was the cam chain and went and replaced the tensioner.
Find your old tensioner, and do the mod that is shown above.
Sounds like your battery or reg/rec is going - maybe both - should start IF you use the choke...........
Old Jun 1, 2011 | 05:47 AM
  #56
roughseas's Avatar
Thanks Shadow and CBRClassic! Will do a full tune up then..valves and carbs and plonk in a new battery. I already have two superdream engines occupying various corners of my house and the last thing I need is mixing the CBR parts with the CB parts Will leave the rattle the way it is if the tune up doesn't fix it.
Old Aug 10, 2012 | 07:22 AM
  #57
t85konrad's Avatar
the pictures have been removed ??
Old Aug 11, 2012 | 02:41 AM
  #58
Naga_Thai's Avatar
Hi t85konrad ( and others who need it)...
Until the photos get "found", here is a copy of that thread that I created earlier; along with some of my additional "parts list" info put into a pdf file that you can download...
http://dl.dropbox.com/u/13500879/Cam...eplacement.pdf
Remember, all credit for this sensational photo "How to" is due to the work of Michael Parks.
Old Aug 11, 2012 | 04:39 AM
  #59
t85konrad's Avatar
Awesome! Thank u good sir. Much appreciated
Old Oct 22, 2012 | 09:59 AM
  #60
Sprock's Avatar
Update : Photo's back in place and relinked thanks to Naga Thai's PDF
Great thread save
