How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Rear Wheel alignment...Made EASY!
Old May 27, 2007 | 08:47 PM
FNQuickF2's Avatar
Default Rear Wheel alignment...Made EASY!
Recently had to replace the rear tire and tried the string alignment method...TOO many steps! I made it a bit simpler...If there is anything else anyone can add, feel free!
RB
Old May 27, 2007 | 10:09 PM
dwhite645's Avatar
Default RE: Rear Wheel alignment...Made EASY!
There's another way that's a million times better. I recently saw it in an ad somewhere and will make my own. It uses the hollow axle and the hollow swingarm pivot mounting bolt where a rod goes through and you measure the distance between the two. I'll see if I can find it again....
Old May 29, 2007 | 04:28 AM
CBRFREEK's Avatar
The folks at my Honda Dealership always get mine right.
Old Jul 24, 2007 | 06:12 PM
hurayta's Avatar
The broom handle trick would work great if you could be positive that the front tire is pointed perfectly straight ahead. I use a 12" length of 1/2" aluminum angle and c-clamp it the the rear sprocket. When the chain aligns with the aluminum angle then the rear wheel is aligned.
Old Jul 31, 2007 | 08:13 PM
DC5's Avatar
DC5
ORIGINAL: dwhite645
I think the product you're refering to is the Rhino Axelign Wheel Alignment tool. Featured in the July 2007 issue of Sport Rider. The site listed is www.rhinomoto.com
Old Aug 12, 2007 | 11:14 PM
ApexClipper's Avatar
Or Gillles Tooling alignment inserts
[IMG]local://upfiles/18103/520D40CD946A40328DA961806F34C808.jpg[/IMG]
Congee
Mar 15, 2013 01:34 PM
dracowing14
Jan 3, 2012 01:26 PM
deadfred
F2 Tech
Jul 15, 2010 01:39 PM
Draco88
Aug 27, 2006 05:13 PM
transambird_2000
Jun 16, 2006 08:50 PM
