Integrated Tail ....Make one yourself for $12
Alright, here's where I'm lost:
I got the board built no problem. I don't understand why I need to run a signal wire from the front running light all the way to the rear. Why can't I just use the running signal from the REAR, where everything is?
Ah, quite right. Thanks!
Ok so i need some help. I did the right side following hangfire's write up and it worked perfect. The i did the left side and now the left bright wont work. I swapped relays and that didnt fix it. I redid my green/yellow connections on the left side and that didnt fix it. I even tried putting the orange blinker wire on the 87 post and the Green/Yellow Bright wire on the 87a post but then the bright worked and the blinker wouldnt work. I swapped bulbs and that didnt fix it. Anyone have any ideas cause i am going nuts tryin to figure it out.. Thanks
