How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Integrated Tail ....Make one yourself for $12
Old Jan 21, 2009 | 07:40 AM
utter05's Avatar
March 2009 ROTM
Default RE: Integrated Tail ....Make one yourself for $12
I'm now angry, i just bought a integrated tailight for 80 and now i see this.
i never even thought about wiring up relays. Crap [:@]
Old Jan 24, 2009 | 02:24 AM
aj_jensen73's Avatar
ok im over my head with this one, I am on step 3 where in you instructions i need to cut the green/yellow wire on the bulb side but due to an accident this bike does not have the right colored wires and I am not sure which bike this tailight is off so i cant look up the wiring schemadic, the 3 wires coming out of the tail light are Black. Black/yellow. Black/white so i am not sure on which ones are for what. I am on hold on this project until I can figure that out. and no the tailight was not installed so i wasn't able to just look to see which ones matched up with what colours. I guess ill see how this project works out but it is a great write up its just me not knowing everything about electrical.
hoping someone is able to help me identify the different colours on the tailight. thanx everyone
Old Feb 2, 2009 | 05:33 PM
redzintimidator's Avatar
the green/yellow wire controls the bright filament in the bulb. if you look at the diagram of the bulbs on page one, you will see it goes G/Y, G, and Bl/Br. Now i am assuming the pin order is the same with your bulbs. Im about 90% certain your solid black is the ground, ie, my Green wire. The next ones im not sure about.I would think that your black yellow is running light(my Bl/Br) and your black white is the brake filament(my G/Y).
Turn on your bike, cut the black white one, turn on your brakes, if that light no longer turns bright then thats the right one. if it still gets bright and the running light doesn't work then its back-***-wards.
Old Feb 13, 2009 | 02:08 PM
chiefF3's Avatar
u can always ghetto rig also.. take a small bevel and make a hole in the back of your tailight housing and insert your current turn signals into those compartments.
that is why my friends did on his bike nad it work OK
Old Feb 13, 2009 | 02:11 PM
ghetto riggin is possible...but this is cool...lol ;-p
Old Feb 26, 2009 | 12:21 PM
Lamar Vannoy's Avatar
That would be simpler since you wouldn't have solder but I think you'd need to swap you g/y and o inputs since the front running light cuts the power when the turn signal is on...
Old Feb 26, 2009 | 12:35 PM
goodwork hangfire! this can be done many ways. i agree with lamar, you will need to swap your NC and NO pins on the relay
Old Feb 27, 2009 | 03:24 PM
Juddelicious's Avatar
Just did mine with the Automotive SPDT Relays, works slick, thx everybody. Used Napa AR143 relay BTW
