How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
installing rear brake rear sets
Old Feb 27, 2008 | 05:22 PM
pr0jktmayhem's Avatar
Default installing rear brake rear sets
i have a 98 CBR f3 and bought new rear sets.
the first one shown is mine with the crack.
the 2nd one is the one im buying..
how hard is this to install>? do i need to change all the brake reservoir stuff or can i just put onthat cracked part without deasling with any fluids?
[IMG]local://upfiles/21303/8AA739D00ED141EE9BD5ADA46A045111.jpg[/IMG]
[IMG]local://upfiles/21303/9CC68E8C9EE348CA9B0BCB077DA0617C.jpg[/IMG]
Old Feb 27, 2008 | 05:32 PM
ffingers's Avatar
Registered Users
Default RE: installing rear brake rear sets
that looks like the piece you are buying has the rear master cylinder and rear caliper along with the rearset...way more than what you need (hope you didn't pay much)....all you have to do is unscrew the rearset from the rear master cylinder...you do not have to do anything with the brakes at all...why the guy is selling the whole lot is wierd to me...but the quick answer is this is easy...
just unscrew the mounting points of the rearset on the bike....the M/C will come off it...then just do the same on the part you bought and line everything back up and you're done....
honestly, it's a really easy job....don't look at the braking stuff at all..just look at it as removing that rearset...
Old Feb 27, 2008 | 05:34 PM
ffingers's Avatar
Registered Users
okay after looking at it again...in the first pic...it looks like the two big bolts on the right are the ones that hold it to the bike...as well as the one allen head on the lower right...
what you'll do is unscrew those...then unsrew the break lever from the M/C on the bike....
on the new part...unscrew the upper left most screws...should pop it off the M/C...unscrew brake lever from that M/C....take the new setup and reverse the removal process and reattach the brake lever to the M/C on the bike...
good luck...
Old Feb 27, 2008 | 06:30 PM
good deal thanks.
Old Feb 28, 2008 | 09:31 AM
ffingers's Avatar
Registered Users
let us know how it went...
zellster
Aug 19, 2019 06:44 PM
nsrt4me
Jul 31, 2010 01:03 PM
skubysnak
Feb 8, 2008 08:13 PM
brancart1
TRG Coating
Jan 5, 2006 03:26 PM
