How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
HOW TO WIRE F4i dual headlights to 99-00 F4!
Old Sep 11, 2012 | 05:50 PM
  #21
ddavis17's Avatar
Originally Posted by h0ndafanat1c
okay, so I got the blue/white wire. It was coming from the F4i bulb connector...the low beam. So I cut the wire and matched it to the blue/white coming from the bulb connector.
Still stuck on this black/red wire from the F4 harness, the white wire (that got connected to the F4 blue wire from the bulb connector, and the blue wire (from the other side headlight bulb connector on the F4i headlight harness.
Hey man sorry for the slow response i haven't been on here in a while. Are you using an f4i harness or an F4 harness because i was using my original f4 harness and taking the second headlight wire from the f4i harness and adding it to the f4 harness. If you have solved it great if not let me know ill respond this time.
Old Sep 11, 2012 | 08:52 PM
  #22
h0ndafanat1c's Avatar
Still didn't get it to work. I have an F4 complete wire harness with the F4i headlight harness. I have the low beam working, just no high beam.
Old Nov 1, 2012 | 08:47 PM
  #23
ddavis17's Avatar
Sorry im all late again lol can you just email me directly at d^d^avis^17@^gm^ail.c^om (Delete the ^) I'll respond faster. I just dont understand why you cant hey it to work. Do you have the headlight relay from an f4i its a little box looking thing.
Old Nov 2, 2012 | 03:47 AM
  #24
RhysIoM's Avatar
Anyone know of / or reckon this conversion would work on my 99 CBR600FY?
if i could plonk the dual lights into here, i would be a happy bunny...
Or do you think i would need to get the F4i light?
Old Dec 3, 2012 | 03:30 AM
  #25
LukeCairns's Avatar
Hello, Done the conversion this weekend, it really helped, i come across the same problem as a couple on here where the dipped beam wasnt working but full was, how to get around that is ... you need another relay, wire the white(and green) wire from the relay to the green on the right headlight, and wire the grey wire from the rela and connect that to the blue one you previously said about for the other relay, problem solved. Cheers
Old Dec 15, 2012 | 11:32 AM
  #26
PSonic's Avatar
great tutorial.
I will convert my CBR600 Hurricane with CBR600RR 02/04 faring, and this solve the problem when I will put the RR headlights.
I have a Civic EG and I bought Angel Eyes and is the same, original headlight is only H4 lamp but Angel Eyes have two lamps and this tutorial probably work too.
Old Dec 15, 2012 | 11:40 AM
  #27
gotcbr's Avatar
Where are you ddavis17??? We need active F4 members! :-)
Old Jan 3, 2013 | 07:47 PM
  #28
ddavis17's Avatar
Sorry im all late lol i have returned from the dead. I will be more active from now on i just been really busy with my new management job out of college. Also im upgrading to a 954 or a 1000rr soon.
Old Nov 17, 2016 | 01:04 PM
  #29
VanessaB's Avatar
Default Anyone still available for help on this...
I did what Davis posted an only my left side turns on.. someone said to add another relay one with the Gray and white/green wire to the blue wire an gray to other replay still nothing helped it only left works... my f4i headlight came already with the two relays connected to them but I'm thinking one is a turn signal relay but it was connected to the headlight slot as the other relay.. anyone help will be appreciated plzzzz...
riclyd
Aug 15, 2013 03:01 PM
jtrusso
May 9, 2013 10:03 AM
(951) Baby Shortee
Mar 24, 2012 12:11 AM
hondarider04
Nov 22, 2009 08:38 AM
bensben
Apr 28, 2007 03:52 PM
