WIRING INTEGRATOR?
Old Apr 4, 2006 | 04:14 PM
bumble929's Avatar
Default WIRING INTEGRATOR?
I BOUGHT A BM MOTOSPORT INTEGRATOR OFF EBAY AND THE INSTRUCTIONS SUCKED. IT HAS 2 WIRES ON ONE SIDE AND 3 ON THE OTHER. WAS HOPING SOMEONE COULD HELP ME WIRE THIS THING UP. THANKS
Old Apr 4, 2006 | 05:47 PM
mandosgreat's Avatar
Default RE: WIRING INTEGRATOR?
Check out my post:
https://cbrforum.com/m_80185/tm.htm
I actually got rid of mine. I don't think cagers wise enough to notice the blinking brake light and assume I am signaling...even when using hand signals.
You can see from the pic. The wire goes to the appropriate turn signal wire. And...I think the brake wires as well...shoot, I honestly don't remember. Damn. I knew I should have taken pics of the wiring without the tape.
Try contacting Hotbodies, should be the same deal.
Old Apr 4, 2006 | 10:55 PM
tutman6's Avatar
with the integrator i got it has two wires on one side, yellow, and green. on the onther side had 3 wires, yellow, red and green. the yellow wire on the side that only has 2 wires hooked to the i think it was left turnsignal wire, which was orange, and the green hooked to the right turnsignal wire wich is light blue. for the 3 wires on the other side it went, for the yellow wire it hooked to the green and yellow wire that goes to the left brake bulb, and the green wire hooks to the green and yellow wire to the right brake bulb ( you'll have to cut the G/Y wires make sure to leave enough wire too hook up to the bulbs).and the wires that came from the harness that were cut, the green/yellow ones those connect to the red wire.
Old Apr 4, 2006 | 11:50 PM
bumble929's Avatar
thanks. i'll have to wait until tomorrow but that sounds like it will work. i'll post an update.
Old Apr 6, 2006 | 04:00 PM
bumble929's Avatar
connected exactly as tutman6 said and many other variations, and it still did not work. is it possible that this unit is defective? or is there some dispute on his wiring explanation?
Old Apr 6, 2006 | 09:14 PM
tutman6's Avatar
possibly defective, Ill grab the instructions from my dads house tomorrow and post a pic of them so you can look at it, maybe it will help , i dont know, ill also take a pic of how i have mine hooked up so you can see that too.
Old Apr 6, 2006 | 10:52 PM
Turnin20s's Avatar
I had pretty much the same problem on my old bike and you will have to get a "loud" flasher. Its made for towing and can handle more load than the stock one.
The side with the 3 wires should be connected to the left turn-yellow, right turn-green, and brake-red. Don't cut your ground wires or the wires for the tail lights. Connect the 3 wires like I said above and then take the two wires that were orginally for the brake side of the bulb and connect the green one to the right side bulb and the yellow to the left side bulb. If it works until you press the brake you will need a different flasher like I said above. I took mine apart about 3 times before trying a different flasher, but now it works fine.
Good luck
-Jesse-
Old Apr 7, 2006 | 04:24 PM
tutman6's Avatar
Turnin20's is right, i told you the wrong wires, I looked at the wiring diagram today and noticed it, the 3 wire side goes to the turn signals and the 2 wire side to the brake bulbs
mach9
How-To: Mechanical
Aug 26, 2012 05:34 PM
turboryan
Apr 26, 2009 11:51 AM
F4iFreak
Jan 20, 2008 10:27 AM
tutman6
Apr 1, 2006 02:47 PM
jcf1977
Nov 18, 2005 12:12 AM
