Wiring Help
Old Jan 18, 2009 | 11:19 AM
Bskinn77's Avatar
Default Wiring Help
My turn signals are not working i dont know almost the least bit about wiring could anyone help me troubleshoot this the bike is an 01 f4i thank you
Old Jan 18, 2009 | 11:29 AM
aj_jensen73's Avatar
Default RE: Wiring Help
I am no pro at fixing bikes but I know my 2005 cbr1000 had a signal relay that is located hear the headlights, there might also bea fuse for your signals.
Old Jan 18, 2009 | 11:41 AM
Bskinn77's Avatar
I have checked the fuse and I have read that there is a signal relay near the headlights what exactly would I be looking for to be wrong with this relay?
Old Jan 18, 2009 | 12:07 PM
well if you find it inspect it, an easy way to test it without having to look up the wiring schemadic is look to see if you have another relay that is the same and switch them to see if your signals work, to make sure the relays are the same look closely at them and there should be some numbers on top as a part #. Do you have a 12 volt test light or a voltmeter by any chance?
Old Jan 18, 2009 | 01:07 PM
Bskinn77's Avatar
yea i have a voltmeter
Old Jan 19, 2009 | 11:40 PM
canadian414's Avatar
Well first... have you tested if the lights actually work? If they're both good your best bet is to find some type of wiring schematic cause if you're planning on having the bike for a while you're going to have more wiring problems sooner or later. Signal relay should be easy to change.
bigwill74
Mar 5, 2013 02:56 PM
leonf4i
Oct 10, 2009 07:24 PM
AALBA2
Mar 31, 2008 08:55 AM
93_ka24det
Mar 25, 2007 06:38 AM
mastice
Nov 26, 2005 04:37 AM
