when i push the starter
Old Nov 2, 2008 | 10:23 PM
amig's Avatar
Default when i push the starter
when i push the starter button all the power on my bike shuts off. i turn the key in the off position and then turn it on again and there still is no power, no dash lights nothing...anybody have this issue? i need help
thanks
Old Nov 2, 2008 | 10:58 PM
Kewl Breeze's Avatar
Retired Moderator
Default RE: when i push the starter
When mine did that it was weak battery. Replaced battery and didn*t have any further problems. Electronic Diagnosis may be in order but I*d start with the battery.
Edit: I should mention that my batt charger showed it as being fine but when I took it in to do a load test, it was dead. Take your batt in for a load test.
Old Nov 2, 2008 | 11:41 PM
HAVOC's Avatar
possible that the blew the mian fuse and thats why nothing will turn back on for you ?
Old Nov 3, 2008 | 01:56 AM
amig's Avatar
idk i let it sit for a while and everything turned back on, but when i pushed the starter again it died, i hear a loud "pack" kind of sound and everything dies again. i checked all the fuses and their all good.
ill try do a load test on it...
thanks
Old Nov 3, 2008 | 02:07 AM
HAVOC's Avatar
battery
Old Nov 3, 2008 | 07:41 AM
fishfryer527's Avatar
+1 a load test will tell you CCA, a voltmeter may only tell you about what the 'surface charge' is.A surface charge is basically volts without amps, that is why it seems like something happens for a momentbut then nothing after that. Kinda like a capacitor discharging.
A new battery should be about 350CCA, but a weak battery of 150CCa will still start the bike. Charge the battery and take it in for a load test, I'd feel comfortable with anything over or close to 200CCA.
nvanvlymen
Aug 2, 2011 02:19 PM
EL Thorsby
Jun 1, 2011 03:04 PM
crashkhanman
Apr 15, 2008 12:49 AM
MikeInCtown
Aug 5, 2007 09:03 PM
