wheels are tighter than before!!
Old Jan 8, 2007 | 04:01 AM
ameersak's Avatar
Default wheels are tighter than before!!
sorry guys, i know this is a carry forward for the WD-40 on rear brakes post, but i really need ur advise..
i just wanted to know that now the front wheel is to tight that it requires a little force to turn it freely! is this normal? i mean, before the front wheel use to turn with little force and it use to spin, now it deos not spin so freely, i have to apply a bit of a force since i have put in the new brake pads..is this all normal? pls reply..thanx
Old Jan 8, 2007 | 01:07 PM
Tahoe SC's Avatar
Default RE: wheels are tighter than before!!
yes it's normal...you won't get any wheel of fortune spin...probably at most 1 to 2 turns. you should hear some pad drag when you push your bike around.
now if it's super duper tight, like when you try to spin the wheel and it goes like .25 turn, then it's too tight.
Old Jan 8, 2007 | 01:10 PM
GEARHEAD69's Avatar
Hey man I don't recommend that you do this, but it sounds like a quick fix but highly corrosive there is tooo much brake fluid in the system!!! if you were to loosen the top of you brake reservoir it will allow the extra fluid out of the system or try this loosen the bleedr valve on the front calipers !! Hold pressure on the brake lever and break the bleeder loose 1 time tighten the bleeder and let off the lever !! DO NOT LET GO OF THE LEVER WITH THE BLEEDER OPEN you will suck air back in the line !! Keep in mind again this fluid will eat the paint off any thing it touches so be very very carefull that should do it!!! Let us know if that does it !! G
Old Jan 8, 2007 | 06:21 PM
hondadriver4life's Avatar
dude keep it up on one then you wont have to worry about your front wheel at all lol
Old Jan 8, 2007 | 08:35 PM
Tahoe SC's Avatar
why are you telling him to remove fluid from his resevoir? unless it's wicked tight, there's supposed to be some drag on it.
Old Jan 8, 2007 | 08:41 PM
abadfish's Avatar
ORIGINAL: Tahoe SC
+1
I agree. There's no need to remove any fluid. The drag is NORMAL.
Old Jan 9, 2007 | 12:41 AM
ameersak's Avatar
thanx guys! i guess it should be normal to have a drag since so many of you agree to it. i will keep it as it is..thanx anyways!. cheers. have a good day!
ameer.
Old Jan 10, 2007 | 03:32 PM
GEARHEAD69's Avatar
He made it sound like it wouldnt turn and I know that sometimes when you put new pads in the piston has to be pressed back in the caliper causing the fluid to over fill the resevoir!! just figured it was easy to bleed them out but yeah the drag is normal!!!
Old Jan 16, 2007 | 01:08 AM
Zippy's Avatar
Have you had the front wheel off? If you have, try this. Loosen the axle pinch bolts on both sides. Take it off the front stand. Bounce the front a couple of times, then retighten the pinch bolts, without putting it on the stand. Then put it back on the front stand and see if it is better. This often solves the problem. It settles the front axle into better alignment.
chuckb
Jan 19, 2021 01:18 PM
DragonCBR
CBR1000F For Sale / Found
Mar 3, 2013 03:25 PM
Gotpepsi
Apr 29, 2011 09:25 AM
energycontacts
Apr 27, 2006 03:06 AM
