Wheels?
Old Apr 30, 2007 | 03:03 AM
chuckb's Avatar
Default Wheels?
will wheels from other cbrs fit the 98 900rr with no mods??
i want an all black rear wheel for my 900 and i found one off a05 600rr for dirt cheap...
just wondering, let me know somehting
Old May 1, 2007 | 01:20 AM
Meeks's Avatar
Default RE: Wheels?
I also need a front wheel for mine and would be curious to know what wheels work as a "bolt on" application. I do not want to modify anything. I heard that the F3 wheels are a direct bolt on but have not personally confirmed this. cbr900 wheels are impossible to come by. My front one is bent slightly on one side. I may just have it repaired. I dont know.
Old May 1, 2007 | 02:10 AM
jasonp's Avatar
Default RE: Wheels?
well i know the 93to95 will not work on a 98 99 the brake roaters are difrent you cant put the roaters from a 93-95 on a 98 99 rim iether i learned the hard way i painted a set of 95 rims and then found out they didnt interchange on my 99 but i think the 99 till 04 f4i rims are the same as the 99 900 just the front is 17"on the f4inot 16 " i hope this helps a little
Old May 2, 2007 | 02:59 PM
900RR Puzzle's Avatar
Default RE: Wheels?
I think that the F4I is the only other CBR that the rear wheel will work.The F3 rear wheel will bolt up, but it is narrower and a waste of time.
On the front, an F3 17" wheel is a direct bolt in swap for the 95 to 97 900RR. On the 98-99, you have to make extra spacers for it to work. I believe that the forks are spaced out 10mm farther on the 98-99, so you have to add about 5mm to each side (spacers). When using the F3 wheel, use the rotors from the 900RR wheel on it. They should bolt right up.
I'm not positive about this, but I think the F3 wheel is a bolt-up deal for the 93 & 94, too. You just lose the mechanical speedometer connection, so you have to switch all of the wiring (harness) over to a 95 to 99 to make the speedometer work. You also need the output shaft sensor, cover, and gages from a 95 to 97, too.
Old May 3, 2007 | 04:11 AM
chuckb's Avatar
Default RE: Wheels?
thanks for the knowledge
Old May 5, 2007 | 09:00 PM
Mad Hatter's Avatar
Default RE: Wheels?
I just tried this swap on my 99 900rr. The rotors are definately a no-go. The 99 axle and spacers were used and they worked. I am not all about re-drilling the wheel to fit the rotors so the F3 wheel and rotors are going to eBay. I have decided to us a 99 VFR800 front wheel as this seems like a better possiblity for a direct swap.
Old Jun 8, 2007 | 05:15 AM
GP COMMANDER's Avatar
Default RE: Wheels?
WOW! ALL 900RRs WHEELS ARE THE SAME! (93-97) IS EXACTLY THE SAME WHEEL! 290mm ROTORS! ON THE 98/99, THE FRONT ROTORS ARE 310mm! THE FORK TUBES ARE WIDER ON THE 98/99 CBR 900RRs! THE F3 FRONT WHEEL 17in. CONVERSION WILL FIT ANY YEAR CBR 900RR! (93-99) YOU USE THE FRONT AXLE AND HARDWARE FROM THAT FRONT 16in. WHEEL! THAT'S IT!!! CONTACT YOUR LOCAL HONDA DEALER OR GO INTO ONE AND CHECK OUT THEIR MICRO FISH! THE (16in. ) FRONT WHEELS ARE ARE ALL THE SAME!!! (93-95) AND (96-97) 900RRs HAD ONLY MINOR CHANGES! 93/94 IS THE SAME AS 95! EXCEPT, THAT WAS THE FIRST 900RR TO HAVE THE CAT EYES! THE 96/97 PLASTICS CHANGED JUST A LITTLE AND THE ENGINE SUCKED! NOW THE 98/99 CAME ALONG AND BLEW EVERYONE ELSE OUT OF THE WAY! THAT ENGINE PURS WHEN SET UP JUST RIGHT! AND YOU HAVE A KICK *** EXHAUST ON IT! JARDINE BABY! JARDINE RACE CAN!!! I HAVE THE F3 WHEELS ON ALL OF MY CBR 900RRs! MY 95 AND MY 98 AND MY 99!!! RUN MICHELIN POWER 2CTs ON ALL OF THEM! FOUND A GREAT SITE FOR TIRES! sportbiketracktime.com $265 A SET! 120/70/17 AND190/50/17!!! TIRE INFO ON 16in. TIRE: RUN THE NEW METZLER M3 16in. OVER THE M2! BETTER TIRE COMPOUND! USES CORSA DIABLO IIIs COMPOUND! REMEMBER, METZLER OWNS PIRELLI!!!
Old Jun 9, 2007 | 02:30 AM
rideordie!'s Avatar
Default RE: Wheels?
just remember, you can use f4i 17 front, but you have toraisethe forks through the tripleclamps to account for the extra height the wheel will give you; if you don't the front will ride too high and give you slow steering effect. i think you haveraise the forks 5mm.
Old Jan 19, 2021 | 01:18 PM
Ian May's Avatar
We have Cbr 919 1999 it has a 929 front end and looking for a bolt in 3 spoke rear wheel no mods if poss and wondering if 900rr would be straight swap over?
DJ929RR
Apr 11, 2011 12:50 PM
99cbr900rr
Dec 8, 2009 04:14 AM
thmper4u
Nov 11, 2007 09:25 PM
Skater
Jul 14, 2007 01:58 AM
