What temp does cooling fans come on?
Old Aug 11, 2010 | 07:22 PM
Sean80's Avatar
Default What temp does cooling fans come on?
2004 600RR... temp hits 212....no cooling fan... run at 170 while riding though no problem.. might just not have given it time to kick on? dunno figured id ask
*EDIT* nevermind. its set to 220 F from the factory lol. --shrug-- guess its just normal for your ***** to be hot.
Old Aug 12, 2010 | 08:13 AM
ridefast's Avatar
i have a 2002 f4i and my fans don't kick on until temps hit right around 226 or so.
Old Aug 12, 2010 | 08:32 AM
Sean80's Avatar
yeah they kicked on when i rode it this mornin when i was at the gas station. were good lol.
off subject but... im not used to the engine wanting to just run at high rpm... even in 6th gear at 65-70 mph its at 3-4 k rpm... dunno if the previous owner put a diff sprocket or if its normal.
Old Aug 12, 2010 | 11:27 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
The Gearing Commander website will tell you what the rpm should be at a specific speed and gear. Also will tell you what the stock size sprockets are so you can compare with what you have.
Old Aug 13, 2010 | 12:16 PM
drunkinmist's Avatar
Sprocket Hauler and Savior
Most fans will kick on at 220-225 all depends on the thermostat that is installed. I cant say for all honda's but at least for the f4i's they come on at 225.
Old Aug 17, 2010 | 02:14 PM
meccaonez's Avatar
Yeah it was 220 on my CBR 600rr and 225ish in the 954 RR
shawnee_cbr
Apr 13, 2013 08:24 AM
cbrmatt88
May 16, 2012 07:48 PM
joeybaila
Jun 7, 2011 02:53 PM
spoolie25
Feb 19, 2011 01:53 PM
ruizs
Aug 9, 2006 03:43 PM
