What part are these!
Old May 23, 2019 | 04:43 PM
cips007's Avatar
Default What part are these!
Hi
I’m trying to determine what the following is on my engine as I’ve had a stethoscope out to determine a light tap/knock noise on warm up. I’ve found the part,actually there are 4 of them,but the one nearest the radiator cooling fan is quite noisy. I I’ve added photo from my manual,there on the cylinder head just in front of the reed valves with an electrical connector on each,there are 4 cylindrical “plugs”
What are these and is it normal for them to be noisy on warm up?
Thanks
Old May 23, 2019 | 06:56 PM
74demon's Avatar
Are you referring to the spark pug tubes that the spark plug is in?
Old May 24, 2019 | 12:19 AM
cips007's Avatar
Ah I assumed the plugs were further back under the tank!
Is it normal to have a noisy one!?!
Old May 24, 2019 | 07:08 AM
74demon's Avatar
No. They only make noise if they are loose or the lead/coil is arcing to something it should not be.
Old May 24, 2019 | 07:20 AM
cips007's Avatar
All seems secure after checking just now,assuming if it is arcing would it not misfire under load etc?
Old May 24, 2019 | 09:18 AM
74demon's Avatar
Any arcing will be a misfire.
Old May 24, 2019 | 09:41 AM
cips007's Avatar
Ah must be ok as it runs sweet,guess I’ll just enjoy riding it then 😉
thanks for your input
Thanks
smokin96
Aug 24, 2013 08:05 PM
dagg92
Aug 4, 2011 10:41 AM
foxens
Feb 17, 2011 04:15 PM
waz57
Aug 22, 2006 05:11 PM
rg_series
Jul 9, 2006 11:04 PM
