UNIVERSAL FUEL PUMP NOT WORKIUNG ON HURRICANE. pleease help
Old May 23, 2011 | 08:58 PM
seatea123's Avatar
Default UNIVERSAL FUEL PUMP NOT WORKIUNG ON HURRICANE. pleease help
ok so ive been running my hurricane with no fuel pump at all for a while and in high gear i cant seem to get enough fuel and it bogs intermittently.
i bit the bullet and spent 50 bucks on a universal fuel pump from an autoparts store, rated at 2-3.5 psi.
installed it and started it.
it starts running all sh*ttily and was smoking out the exhaust,
so im assuming its running really rich.
so im pretty pissed about the 50 bucks i wont be getting back.
any advice from anyone would be greatly apreciated.
thanks.
Old May 23, 2011 | 10:38 PM
Well, I'm thinking that it's either ebay, or an additional $140 on an OEM fuel pump.
Old May 24, 2011 | 12:42 AM
seatea123's Avatar
yeah im coming to terms with that.
curious though why is this happening? how would this be different to the factory pump.
i feel like if i spend another 130 on a factory one its going to do the same thing.
Old May 24, 2011 | 12:58 PM
seatea123's Avatar
What color was the smoke ? ( white = to much fuel .... black = oil burning )
I agree that you prolly are better with an OEM one .... they should be available on Flebay ...
BTW ....If this is the same issue that you posted on the 600 board , may I ask a stupid question ....? DID you strip and clean the carbs before you put the fuel pump on ....
the smoke was white, and i have already cleaned my carbs. after i cleaned them the bike runs almost perfect. there is no lag in power until im in about 5th or 6th gear and ive sucked up all the fuel in the bowls.
Old May 24, 2011 | 09:28 PM
seatea123's Avatar
Yer , sounds like she was flooding before you cleaned them , but it good to hear that she is running ok now agter your clean job ..
Sounds like lack of fuel pressure , so a replacement stock pump will be the go I recon ...
good luck ..
thank you man. im going to get a new stock pump. cheapctcleparts.com has them for $136.18 before tax and shipping.
do you recommend buying used on ebay? seems like a shot in the dark as far as how well it will function. and there not selling for much less than a new one. cheapest one i found was like 120 or sometihng.
does anyone know of a site selling new jdm parts for cheaper than cheapcycleparts?
dennisgb
Dec 11, 2012 01:19 PM
landfast
Jun 14, 2011 05:43 PM
rwl1955
The Hurricane Saloon
Sep 24, 2010 09:04 AM
Scrufdog
Sep 16, 2009 11:13 AM
zblad
Dec 5, 2008 01:14 AM
