uhh ooo new problem here
when i start my bike and still have the clutch in it sounds fine well somewhat fine but when i let out on the clutch and let it idle in neutral there is a low knocking sound coming from below the filters but above the motor i believe any ideas at all????
well i know somtimes in my car when the oil level gets low my motor makes a knocking kinda noise...so maybe u might wanna check and see if u got enough oil in there..but usually when somthings knocking specially the motor thas not to good..try puttin some oil in there and see if that helps
What year is your bike? how many miles etc.
Sounds like a noisey clutch, We have that quite a bit with the dirtbikes, Do you clutch wheelies?
First thing to check would be the clutch springs, you will need to mic them and also check the pressure plate for warped or cracks.
dewthedoo05
Sep 4, 2007 09:32 PM
