Tick over problem.
Old Apr 20, 2007 | 03:21 PM
craig wilson's Avatar
Default Tick over problem.
Any ideas as to why my CBR600 has started to stammer when ticking over? The book says it should idle at about 1200rpm, which it does until the engine warms up. Then, at normal running temp, it fluctuates between 500rpm and 1200rpm. Sometimes, on odd occasion, it stalls. Even if I put the choke back on, it still fluctuates by around 700rpm. Someone suggested I need to re-set the carbs. Someone else said the timing chain needs looking at. Anyone out there had a similar problem?
Old Apr 20, 2007 | 03:50 PM
Tahoe SC's Avatar
Default RE: Tick over problem.
did you knock a vacuum hose loose?
Old Apr 21, 2007 | 02:44 AM
ThisisMickey's Avatar
mine fluctuates about 200rpm's i assume i need a carb sync. But also I got a manual CCT and it seemed to help it a little bit. It used to fluctuate about 400 rpm's. I would definatley recommend a manual CCT its about 45$
rickscbr
Sep 13, 2008 10:17 AM
Chrono8285
May 21, 2008 07:06 PM
wande00
Jun 23, 2007 05:08 PM
byc_panty
May 12, 2007 10:20 AM
Eminent
Dec 13, 2006 10:56 PM
