Think my battery is dead?
Old Jun 22, 2011 | 08:25 AM
Dally CBR's Avatar
Default Think my battery is dead?
Hello all,
Well I have just finished the R1 rectifier conversion on the CBR as it was charging at 18.5 volts, anyway charged the dry ish battery for about 1 hour after topping it up (only 4 months old ) and it was bubbling away so I fitted it to the bike (it was at 15.5 volts ) and hey presto it turned over once and died in the ****.
Have I cooked my battery beyond use? Should I try charging it for longer?
Cheers
Old Jun 22, 2011 | 11:46 AM
highwaypatrol's Avatar
Hi. The voltage seems a little high as 14.2 volts or thereabouts is normal and you may have damaged the battery if it was charging at 18.5 volts before you changed the Recifier. Have you checked the main fuse to see if it has blown? I think that you should let a battery stand for a while after charging, but I don't think that is your problem. Have you tested the voltage across the terminals of the battery since the bike stopped? Also your battery cells shouldn't have been dry if that's what you were inferring by the term 'dryish'. Try filling the cells with distilled water up to the correct level, let it stand for a hour or so then check the voltage without it being connected to the bike. Leave the earth connection disconnected to save taking the battery out. Let me know how you get on?
Originally Posted by Dally CBR
Hello all,
Cheers
Old Jun 22, 2011 | 11:55 AM
slowride's Avatar
Sounds like the cells may have shorted across the plate. If the battery was over charging and dried out the cells then I would bank on buying a new battery.
Old Jun 22, 2011 | 01:20 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
What kind of charger did you use on it?
Old Jun 23, 2011 | 07:29 AM
Dally CBR's Avatar
Bought a new battery today and connected it up. All is sweet, thanks for your advice.
WhiteHawk
May 31, 2025 07:11 PM
evans21
Sep 5, 2013 02:02 PM
estate4life
Sep 20, 2012 01:52 PM
MDZ600F4i
Aug 6, 2006 02:26 PM
Whitt944
May 24, 2006 01:54 AM
