Testing the rect/reg PLEASE HELP
Old Mar 22, 2005 | 09:12 PM
Phantom_Rider's Avatar
Default Testing the rect/reg PLEASE HELP
I have the same promblem one other guy on here has. I am a mechanic but not a motorcyle one........I have hooked a volt meter to the battery and im getting about 11.90 at idle and a 3k rpm's I get 12.6v I know this is off, what im wondering is how to test the regulator and the stator. I know you can do an ohm's test on the stator, but which wires and whats the reading supposed to be? Second how do i test the regulator? Thanks for the help guys.
Rob
Old Mar 28, 2005 | 05:58 AM
beater 900rr's Avatar
Default RE: Testing the rect/reg PLEASE HELP
try the shop manual i dont know what bike you have but i posted a link that might have it
Old Jul 15, 2005 | 09:54 AM
fasthigh28645's Avatar
the reading for the resistane should be between 0.0 and 0.1 ohms and you test it using the yellow leads.If it shows that it is charging on the meter it is probally not the reg/rect. The problem may be the altenator itself or it could just be a bad battery.
Old Jul 15, 2005 | 01:53 PM
abadfish's Avatar
Try this. Its for an F3 but you should be able to make it work for you:
http://forums.cbrworld.net/forums/140473/ShowPost.aspx
fireallyourgunsatonce
Sep 6, 2012 07:57 PM
Wolphe22
Jan 11, 2012 06:29 PM
cbr_mike
Sep 30, 2011 10:38 AM
smr96
Aug 8, 2010 07:31 PM
danny600rr
Nov 17, 2006 02:17 AM
