temp guage
Old Oct 23, 2005 | 12:25 PM
brian's Avatar
Default temp guage
Wandering if my temperature actually works, the bike never seems to go into the middle section of the guage. I live in northern Canada and the temp is rather cool, does this effect it?
Old Oct 23, 2005 | 06:30 PM
TeeDub's Avatar
Default RE: temp guage
The bike is 16 years old, maybe the thermostat is stuck open.
Old Oct 24, 2005 | 03:59 PM
MapJr's Avatar
The bike is old but I believe your thermostat is working. Cold does affect your temp in very cold climates and high elevation. Do this, put your bike in an area closed off from the wind and outside temperature. Put a heater near your pipes and see if the temp goes higher than what you are use to seeing. If it doesn't after 2 minutes of idle...check your thermostat and coolant mixture. Hope this helps.
Old Oct 24, 2005 | 04:04 PM
Patrick's Avatar
does it run well?
akrite
Sep 30, 2013 02:22 PM
Bugkiller
Sep 23, 2012 10:20 AM
bambam
Dec 18, 2009 12:33 PM
rdrink25
Jun 25, 2007 01:01 PM
ericej2344
Jun 5, 2006 05:08 AM
