TANK PAD WON'T STICK
Old Jul 11, 2007 | 06:45 PM
aaron1085's Avatar
Default TANK PAD WON'T STICK
silly question but... this is the 2nd tank pad i CANNOT get to stick and i dont know why?!!?!
they are good for about a day, and then start peeling on the edges, any hints?
thanks!
Old Jul 11, 2007 | 07:50 PM
demonchild's Avatar
Default RE: TANK PAD WON'T STICK
Clean and DRY. clean with a solvent then wipe with a moist towel that ONLY has water on it. most solvents leave residue. allow the water to dry.
Old Jul 11, 2007 | 10:57 PM
TK954RR's Avatar
Jan 2009 ROTM
What demon said, but i will add a lil bit. Make sure your tank spotless. I will us a clay bar or alternative if there is any stuck on debris in the area. Wash the area with dawn dish soap ( that will take off any wax type protectant). Then i again clean it up with rubbing alcohol, and make sure its dry with a clean lint free towel. When your gonna apply it make sure bike is in the shade and not too hot, around70 F is ideal.
Old Jul 12, 2007 | 03:15 AM
aaron1085's Avatar
thank u!
Old Jul 12, 2007 | 12:09 PM
CBRCRF's Avatar
Dont know if this will help but I also held it behind my exhaust for a min to soften the pad so it mould to the tank when I was putting it on. It made it easy to get all the edges down and sticking.
Old Jul 12, 2007 | 02:48 PM
Tahoe SC's Avatar
yea heat the sucker up before applying...also cutting the edges so they are rounded will help prevent lifting.
Old Jul 12, 2007 | 08:53 PM
lungfish13's Avatar
I had the same problem with two tank pads. Then I decided to go with this http://www.thetankslapper.biz/online...store/main.htmand haven't had any issues since I bought it in November. I mainly went with this so because you can remove it and put it back on and it's almost unnoticeable. I agree with everyone else here on the fact that it helps to heat the it up before you stick it on. I used a hair dryer.
Old Jul 13, 2007 | 07:12 AM
fishfryer527's Avatar
My next tank pad will be that invisible film that you put on the front of cars. Invicta-shield is one name, but there are a few others. I have it on my S2000 and you can barely see it.
underground-mpyre
Dec 10, 2013 01:25 PM
lordexpectation
Dec 19, 2011 04:22 PM
CaNsA
Jul 1, 2010 09:42 PM
Aussie Johnno
Feb 26, 2010 08:40 AM
89ls1
Mar 7, 2008 02:32 PM
