TANK PAD WON'T STICK
RE: TANK PAD WON'T STICK
What demon said, but i will add a lil bit. Make sure your tank spotless. I will us a clay bar or alternative if there is any stuck on debris in the area. Wash the area with dawn dish soap ( that will take off any wax type protectant). Then i again clean it up with rubbing alcohol, and make sure its dry with a clean lint free towel. When your gonna apply it make sure bike is in the shade and not too hot, around70 F is ideal.
I had the same problem with two tank pads. Then I decided to go with this http://www.thetankslapper.biz/online...store/main.htmand haven't had any issues since I bought it in November. I mainly went with this so because you can remove it and put it back on and it's almost unnoticeable. I agree with everyone else here on the fact that it helps to heat the it up before you stick it on. I used a hair dryer.
