tail light problems
Old Feb 27, 2012 | 07:09 PM
03rep's Avatar
Default tail light problems
03 600 rr tail like is lit but does not get brighter when eather brake is hit
Old Feb 27, 2012 | 07:33 PM
CJardine's Avatar
Track junkie & modaholic
Check the bulbs with a multi meter, start there. cheapest fix
Old Feb 27, 2012 | 08:16 PM
03rep's Avatar
tail light is lit not sure if its on dim or stuck on bright for the brake and turn signals do not work at all i check conections and ajusters for the brake still gotta look at fuses
Old Feb 27, 2012 | 08:22 PM
CJardine's Avatar
Is the light LED? if not the bulbs are most likely dual filament and they might have burned out. If the turn signals don't work as well you can get some dielectric grease and pack the connections. But I would start with a multimeter and test the connections and bulbs first.
Old Feb 28, 2012 | 07:38 PM
03rep's Avatar
I figured it out thanks micro fuse
FightasCBR600
May 26, 2011 09:09 PM
Jerzdan
Aug 3, 2009 02:16 PM
__Z__
Jul 14, 2009 11:45 AM
d_tran
Apr 28, 2009 09:54 PM
foxens
Nov 7, 2008 10:23 PM
